![]() | Home > Technical (L322) > Normal Height only then red triangle/ Don't exceed 30mph? |
Diagnosed as a problem with the suspension compressor apparently. LR assist diagnosed it on the driveway and due to return tomorrow to replace it under warranty in situ.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Did they sort it Ryan? There is nothing that can't be fixed with a hammer😜😜
Apparently so Mark... New compressor and relay switch |
Having now read the LR report the fault codes were:
Mrs pld says the car seems to sit a little lower at the back since this recent warranty repair was done by LR assist on our driveway.
Could be right, checking to see if it's dropping over time. Wouldn't necessarily see it after a couple of hours. There is nothing that can't be fixed with a hammer😜😜
Car been returned to us... I can see that the rear arch is closer to the top of the wheel than the front... They obviously didn't have it long enough |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
there should be a cm difference between the front and rears Ryan. ... - .- -.
