Home > Technical (L322) > ticking noise inside cabin
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
does anyone know what the ticking noise (sounds like a clock ticking) is coming from inside the car.
was really bad 2 weeks ago with the really cold weather
not sure where the noise is coming from but you can also hear it from outside the car when the pre heater is on .
when you turn the pre heater off or unlock the doors it goes away
stratstone milton keynes have heard it but say they have never heard this before and are looking into it (that was 2 weeks ago)
Post #42363 15th Dec 2010 1:18pm
nobody knows ian.... Shocked ......but these might help
http://www.fullfatrr.com/forum/topic552.ht...king+noise
http://www.fullfatrr.com/forum/topic3605.h...king+noise
http://www.fullfatrr.com/forum/topic1972.h...king+noise ... - .- -.
Post #42371 15th Dec 2010 1:44pm
SteveMFr
Site Sponsor
Do you have a diesel (helps to know... Razz )? If so, you're pre-heater will be running as a supplementary heater (FBH) when the motor is running too. The fuel pump for the FBH ticks - although it's more rapid than a once-a-second clock tick. That would be the only connection I can make between the pre-heater and the running motor. Generally the pump is isolated in a rubber mount and you can't hear it - but yours may have shifted. Have you had any work done to the fuel tank (new pump, new sender, etc)?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42372 15th Dec 2010 1:48pm
he does have a diesel steve, hover mouse over little car in avatar area and all will be revealed... ... - .- -.
Post #42377 15th Dec 2010 2:14pm
SteveMFr
Site Sponsor
ahhh haha Embarassed
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42399 15th Dec 2010 4:26pm
T24RES
Mine does this too. I assumed it was the pump for the webasto?
iancollins may i say, what a great username?
Rgds Ian Thumbs Up Ian
Post #42415 15th Dec 2010 7:24pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Mine does the 1 second tick too while the FBH works and I have a wooing noise while it's on too...
Post #42423 15th Dec 2010 8:27pm
SteveMFr
Site Sponsor
The mini jet engine sound is normal (RR owners are supposed to be so used to that from their Lear jets that they don't notice it Laughing ). The ticking is not. Should not be there. I hear nothing from my pump. And, unfortunately, my Lear has been reposessed... Crying or Very sad
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42425 15th Dec 2010 8:52pm
adara
Actually the ticking only lasts 10-15 seconds at the beginning. It did this from the first day I had it.
Post #42427 15th Dec 2010 8:57pm
dan_uk_1984
Mine doesnt do this
Post #42430 15th Dec 2010 9:21pm
T24RES
dan_uk_1984 wrote:
Mine doesnt do this
My 2005 X5 had an electro-magnetic fuel pump for the webasto, this was silent.
Have the fbh fuel pumps been changed for the newer model FFRR? Ian
Post #42433 15th Dec 2010 10:04pm
SteveMFr
Site Sponsor
No, they are still the same. The pump actually meters the amount of fuel, and by varying the frequency, the mixture can be changed (petrol and diesel actually share most components - the ecu has a different frequency for pumping one vs. the other).
Adara, you are prob only able to hear the pump until combustion noise drowns the ticking out. If it wouldn't continue ticking, your fbh would not continue running...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #42438 15th Dec 2010 10:56pm
Sportex
England 2008 Range Rover Vogue TDV8 Stornoway Grey
mine does this, like the ticking of a clock! also when first moving sounds like a fan struggling to work properly??? No body told me there would be days like these
L Reg dark purple/burgundy sort of Disco
R Reg very red disco
Bright Silver disco TD5
Sort of bright girly powder blue disco TD5
Gone (a while back) 1999 P38 4ltre Autobiography. 13 miles to the gallon, 10,000 miles to the engine
Gone MY06 RRS HSE Rimini Red
Gone MY10 RRS HSE Purple
Gone 2007 TDV8 Vogue OF Stornoway Grey (In Love again)
2011 4.4 TDV8 Vogue Baltic Blue
MY66 VOGUE TDV6 3.0 Red
Post #42440 15th Dec 2010 11:19pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
mine ticks all the time its on until the engine is up to normal temp.
When i first heard it sounded like it was coming from under the f/n/s seat...
Post #42456 16th Dec 2010 8:28am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Sportex, both the TDv6 RRS and the TD6 FFRR I had did that fan running bit for the first 1/4 mile or so, I was told it was something to do with the gearbox oil cooling or the Viscuous Coupling cooling sensor - nothing to worry about. Neither the RRS TDv8 nor my current TDV8FFRR do it though. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #42463 16th Dec 2010 9:52am
