Home > Technical (L322) > 4.4 tdv8 12MY restricted Performance
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Hi there, was wondering if anyone has experienced or could shed light on this.
Soon after i had the vehicle (22Oct) it went into restricted performance after hard acceleration up a hill at 60-70mph. a fault code reader showed: P244B, P004B, P00CF. Clearing the codes and everything resumed as normal.
When last at the dealers they couldnt replicate the fault and neither could I - until Christmas day some 3k miles later.
Again hardish acceleration upto 70pmh and Restricted performance came up, with P004B. clearing the code and again back to normal.
toyota have some good info here: http://www.moranbahweather.com/toyota/repa...l007x.html
from that would it seem the vanes are not operating correctly due to DC motor issue? Cheers
James
Post #419903 28th Dec 2016 9:37pm
Baltic Blue
It might be worth getting the turbo air change over valve checked.
I had exactly the same symptoms,i.e. Restricted Performance when I put my foot hard down to overtake slow moving traffic on the motorway.
Apparently the change over valve was modified to prevent it sticking .
There is a service bulletin detailing the fault and fix.
Mine was changed under warranty. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #419910 28th Dec 2016 9:55pm
JST
thank you for heads up, did they give you a part number for the valve or any further detail? or the tech number?
Did your do it all the time? or occasional? Cheers
James
Post #419912 28th Dec 2016 10:11pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Could it be slight degradation / split in one of the hoses from intercooler to inlet manifold? They're well known for failing (on 3.6 TDV8, anyway - can't see why it would be any different on a 4.4). The top two hoses are fairly easy to get at and inspect. My thinking being that a split might only open up under pressure, which would explain 3k trouble-free miles between problem.
Steve Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #419917 28th Dec 2016 10:49pm
JST
Hi Steve, good point, although it is used hard between the 3k miles so i am not sure as its not a consistent fault. will check the hoses. Cheers
James
Post #419971 29th Dec 2016 11:57am
Baltic Blue
JST,
LTB 00504 dated 18/2/2013. refers.
Cheers
Post #420000 29th Dec 2016 3:03pm
JST
thank you Cheers
James
Post #420007 29th Dec 2016 3:48pm
JST
still does it, hoses are good.
P00CF comes up now.
and see other thread - its using oil, but not convinced they are related but could be, hence didn't put this info in other post! Cheers
James
Post #427885 15th Feb 2017 5:44pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I had a similar issue last year whilst in France and it turned out to be a cracked inlet manifold. The French mechanic demonstrated it by standing on the accelerator whilst I held my hand over the manifold. Lots of air escaping from the split manifold. It appears the split only caused an issue when the car was on a long climb with the caravan on the back, I.e. Under load.
Post #427909 15th Feb 2017 7:30pm
JST
cheers Buzz, that has been suggested previously and your comments help reassure this. was that on a 4.4? i am aware of is it being a problem with the 4.4s Cheers
James
Post #427916 15th Feb 2017 8:18pm
Buz1500
Hi James, yes, a 4.4
Post #427919 15th Feb 2017 8:22pm
JST
thank you. Cheers
James
Post #427930 15th Feb 2017 9:16pm
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
Hi JST,
Did you ever get to the bottom of your "restricted performance' issue?
I have the same problem on my 2012 Westminster. Red warning, limp home mode and an oil patch on my driveway. Just took it in for diagnostics and the garage thinks its the EGR valve, but that doesn't explain the oil loss.
Would be good to hear what yours turned out to be and how they fixed it?
cheers
Tony 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #503935 4th Feb 2019 5:58pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Tony,
Urrr, feeling a bit guilty here!
Hopefully you'll find the answer soon
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #503947 4th Feb 2019 6:52pm
JST
hello,
yes a combination of things.
leak between the two dpf sensors meaning it wouldnt pass the full boost air pressure test thing that they run on testbook(?)
plus the turbo drain mod was needed as oil was filling the dpf and combined with above giving incorrect soot level readings. Cheers
James
Post #503978 4th Feb 2019 11:44pm
