Home > Maintenance & Mods (L322) > Fuel Gauge erratic
Page 6 of 6 <123456
Jimmy86
Thanks. Where were you able to get a replacement white connector from?
To be honest, not checked the readings, not got much experience with the electrical side of things but was happy to crimp a couple of connectors.
Everything seems to be working for the moment but suspect that white connector will need replaced in the near future.
Post #714306 18th Mar 2025 8:58am
Rackers
I had to cut the white connector off my existing pump assembly and then cut & solder to the replacement pump that arrived.
Long story short, the replacement pump was second hand but the grounding PIN in the plug had melted away so the white plug was useless. The plug on my existing pump was fine, so chop & solder it was!
Cheers
Post #714348 18th Mar 2025 3:07pm
Page 6 of 6 <123456
