![]() | Home > Technical (L322) > buzzing, resonance,vibration |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
so its been established that the gap iidtool cannot read these values as LR havent made it possible to do so.... anyone have ideas on how i can get hard evidence to show if the injectors are faulty or not... |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Leak off test? |
what's that then greg? |
thanks you two.... |
Basically stan, it will show up any injectors that are over fueling.
i was wondering how it was done |
Basically you remove the fuel return pipes (the daisy chained ones) and fit individual pipes, they are then collected in individual calibrated containers... the engine is then run and the fuel return from each injector can be measured... they should all be about the same if the engine is ok, and there shouldn't be much fuel leaked back to the tank. If any of the containers fill up with more fuel (10%+) than the others, it indicates that there is a blockage within the injector which requires attention. If they all leak back more than a few cc's of fuel then the they all need looking at ![]() ![]() However if your engine has covered over 100K then it's worth having all the injectors properly cleaned and tested on a rig, because there is a danger that your reconditioned injector will preform better than uncleaned injectors, and introduce an imbalance again ![]() The main reason for getting a Bosch specialist to do the test is a you'll need to invest in some single outlet fuel return unions, and the ones that are fitted to the engine as standard are top quality plastic that are prone to breaking... while they don't cost a lot.. how many do you buy? you could end up buying 8 x 90 degree unions, 7 x 180 degree unions to replace broken ones, you'll also need a lot of pipe and containers and some thing to hold them in.. by the time you've shelled all that out your close to the hours diagnostic fee... Plus if you go to the stealer and say I have found a blocked injector they might not take much notice.. but if you say that the Bosch specialist has found blocked injectors they will have to take notice ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
^ i knew that .......
