![]() | Home > Technical (L322) > Judder when braking |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
Agreed |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
check the rears for sticking calipers, the symptom is pretty hard to pin down, could be bushes, could be fronts, could be rears. If it was doing it before you changed the discs then i would check the rear end for hot discs after a run. They are notorious for sticking. sometimes caused by the pads sticking in the caliper carrier, sometimes by the actual caliper. First job is to get the carrier off clean off the rust and corrosion where the pads sit and fit some new pads and re build making sure that the pads are not tight where they sit. There is nothing that can't be fixed with a hammer😜😜
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
Had this issue, rear caliper sticking. |
Thanks Guys, Sounds like a big session checking everything. |
