Home > Technical (L322) > Please help Tdv8 IId live data for fuel rail pressure needed |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 |
Hi guys I wonder if anybody with a 3.6 Tdv8 and a iid would be so kind as to help me by posting a log of there fuel rail pressure readings during start up as I'm at a loss as to a fault I've being having and would love to see some for comparison,
27th Jan 2017 9:52pm |
Nobody?? Thanks anyway |
12th Feb 2017 10:43pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
try maybe posting here,https://www.aulro.com/afvb/l320-range-rover-sport/
13th Feb 2017 10:04am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
I will have a look on mine for you and post the results! |
13th Feb 2017 7:29pm |
Does this give you the info you need??
13th Feb 2017 8:32pm |
That's exactly it brilliant thanks, I will try and figure out how to post mine like that,
13th Feb 2017 9:02pm |
13th Feb 2017 9:14pm |
Glad I could assist with the data for you. As for assisting with the fault not sure I can offer too much assitance there. I assume that you havent had any codes come up on the IID tool? Also is there plenty of fuel in the tank and has it has the fuel filter changed recently? Outside of that there could be a leak or issue with the high pressure fuel pump.
14th Feb 2017 12:28pm |
It's been a long road with a few curve balls thrown in for good measure e.g it starts instantly hot or cold if a booster is attached which led me down a path of earths,battery & starter etc but now I'm fairly certain it's injector related or like you said the hp pump I did have rubbish low side fuel pressure so the tank has been down cleaned and pump module replaced and the filter which did resolve the hesitation and most of the codes, I'm just left with p0191 which is a rail pressure fault that incidentally doesn't throw up when boosted. Thanks again for the log |
14th Feb 2017 11:40pm |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 44 |
Whats your battery voltage while cranking? if your battery is tired and the voltage drops below 9.6v it will cause all sorts of issues, the electronics tend to throw in the towel at that voltage.. 2018 L405 Autobiograpghy
18th Feb 2017 11:48am |
Hi the battery voltage was dropping to around 10.1v cranking and because of the situation with the booster even though the car spun over fast enough I replaced the battery just in case but it made no difference, I'm hoping to get the injectors checked next week so hopefully that will be the answer, I'm just hoping it's only a couple as I don't fancy doing 8 in one hit |
18th Feb 2017 7:21pm |
Just a quick update, it looks like I need 4 new injectors and will update when they're done with the new data |
3rd Mar 2017 10:18pm |
8th Mar 2017 9:23pm |
Nice work glad its all sorted and i could be some small help! Atleast it was only 4 rather than 8 injectors i suppose! |
8th Mar 2017 9:29pm |
