![]() | Home > Maintenance & Mods (L322) > Rear wash/wipe leak repair. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8782 ![]() ![]() ![]() |
Add that useful info to the article in the wiki, no one will see it here when they do the fix... |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
T'is locked so needs someone more important than me to add it. 🙂 |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
How long does this leak take to start? I have a Nov 2010 manufactured facelift L322 and intend to keep it for another couple of years or so. Does the face lift model also suffer with this problem? I'm wondering if I should be doing a bit of preventative maintenance? 4.4 TDV8 Vogue Baltic Blue MY11 |
Hard to say. Mine is 10 years old and has just started but if you were to get on and replace the seal with two seals then it would prevent the spindle from corroding in the first place! |
Could this be added to the Wiki please? Saves a good bit of time and effort if you are just repairing the leak! |
