Home > Technical (L322) > Drivers heated seat issue...
MattyB1983
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
Hi people,
So from a quick google search I'm guessing this is a common issue but thought I'd ask on here to see what you guys think...
Recently got myself my first Range Rover (2004 td6) and am working my way through the few minor problems it has. One issue is the drivers heated seat does not work, apparently it started playing up shortly before I purchased it. When I press the button the lights come on but after just a few seconds they go out.
Where do I start, is it something I can tackle myself (I'm fairly hands on with cars) or is it going to be a major drama to sort ???
Thanks and look forward to your help and advice
Matt.
Post #426499 5th Feb 2017 10:16pm
Dolphinboy
Try checking the connection under the seat first. With all the moving back and forward, the wire sometimes gets caught and chafes or provides a poor link.
Post #426511 5th Feb 2017 11:16pm
MattyB1983
Thanks, that'll be my first port of call next weekend then Thumbs Up
Post #426514 5th Feb 2017 11:31pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
If not connections then common issue is the heater element breaking/becoming disconnected.
Have a look at this thread http://www.fullfatrr.com/forum/topic41063.html
You may not have exactly the same seats as mine is a 2006 AB but the principles are the same.
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #426561 6th Feb 2017 2:48pm
MattyB1983
Fantastic thread chap Thumbs Up
Certainly not a quick and simple fix, let's hope the 'plug wiggle' does the job for me Neutral
Post #426656 6th Feb 2017 11:33pm
