Home > Technical (L322) > Programming the remote for FBH |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Sorry to hear that.
3rd Feb 2009 8:40pm |
dark.soul999 Member Since: 04 Feb 2009 Location: Bucuresti Posts: 9 |
Are you sure that remote its for FBH ?
4th Feb 2009 3:38pm |
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 |
Mine is definitely a FBH remote, but the instruction says press un-lock, so I pressed the unlock on ignition key Unless it meant "off" on the FBH remote |
4th Feb 2009 4:01pm |
Try this: remove fuse and wait 15-20 seconds, reconnect the fuse and within 5sec press OFF button from FBH remote. If this procedure its not work, try to repeat procedure with ON button. The red/green led from remote must lighting aprox. 2 seconds if all OK. |
4th Feb 2009 4:54pm |
Thanks, just asked the dealer, remove fuse, I should press the "ON" button from FBH remote within 5 secs, NOT the unlock button from the ignition key.... |
4th Feb 2009 5:45pm |
Ok then...I've just tried again by pulling the fuse out, and pressed ON, tried again, then pressed OFF, not working
4th Feb 2009 7:57pm |
My mistake , but before to advise how to program the remote, should be ask what model year its vehicle. The electrical schematics it’s changed from MY 06 |
5th Feb 2009 8:48am |
Should this not take 20 - 25 secs to do , not 5 mins |
5th Feb 2009 11:21am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
At least we now know how it's done if anyone else requires instructions. Thanks Kin. Discovery 4 HSE
5th Feb 2009 11:49am |
Mine is MY 06,and your advice was right Mick..it's a 5min job, first you have to find a 10mm spanner to un-do the nut on the battery, and then re-connect and tighten the nut again RRUK, no need to thank me, its all part of the service |
5th Feb 2009 1:31pm |
Found it! |
18th Nov 2010 2:15pm |
