![]() | Home > Technical (L322) > Preheater - Battery Failure???? |
I imagine the extra unburnt fuel going into the cats, and the increased cat warm up time wouldnt be too good... ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35763 ![]() ![]() |
i suppose the RR is set up for using a fbh and any messing with that will affect others parts of it... ... - .- -.
wheres the option on the screen then dexter? |
Do you know how the dealer tests the battery? It's in the workshop manual as: Open bonnet. Look at inspection light on battery. If Green OK, if dark, replace. This is not a failsafe way of testing a battery, but it is the LR way of "testing" a battery. ![]()
The FBH does have a pre-set option, however, this clears the following day. You can set it to come on at 8AM for example, but after its run once it has to be manually set again.
I'd love to see this - the car is quite un-ecconomical when driven at speed, perhaps there is a TB to limit the speed to 50mph? I'd love to know how much you baid to be fed this load of bulls1t? It's unfortunate that dealers seem to know so little about the pre-heater, hence why they were very rarely specc'ed, the dealers just didnt know what they were. ALSO, every time you completely discharge your battery it looses about 10% of its capacity to hold a charge. So if you've had several flat batteries it will never be the same again. ![]() Last edited by dan_uk_1984 on 23rd Jan 2011 5:09pm. Edited 2 times in total |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
Hi Dexter,
First thing that came to my mind too. Immediately. Imagine the consequences if this were not the case: you stay at a small B&B where the car is parked outside so you set the pre-heat. The next day you park in your own mini 1-car, RR-sized garage with, in total, only around 10 cu.ft. more space than the volume of the RR. You forget to turn off the pre-heat and the next morning those 10 cu. ft. are solid CO. Your dog, who was accidentally locked in the garage overnight, is thoroughly dead. ![]()
The FBH uses quite a bit of power when it initially fires - above all due to the glowplug. Once it is burning, it draws very little: only the fuel pump, combustion blower, and the vehicles fan draw power - the latter being the biggest draw. The last 10 mins probably only make up 10-15% of the total power consumed by the battery. If LR does have a TSB on this, I'd assume that it is mainly because the fan is run too fast - and re-programming the FBH is easier than re-programming the HEVAC ECU to lower the fan speed. It seems to me to be a rather poor fix. I'll try to check the TSB's sometime.
Agreed to 100% on both counts. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
kil2508 Member Since: 05 Sep 2010 Location: Wales Posts: 20 ![]() ![]() ![]() |
update on my FBH issue.
I've read no info in the WSM that says when you open the door the FBH comes on. But I only have Rave, perhaps someone else can verify this?
Just to clarify its when i unlock the car it automatically comes on so already on before i even touch the car, and once I have then stopped it and say have the boot open for getting shopping and I shut the boot it come on.
Does it do it EVERY time you unlock the car? If so this should be pretty easy to replicate and rule certain elements out.
Hi
OK, next try unplugging the remote reciever I guess? The other thing I "think" you can do is reload/flash the firmware of the Webasto ECU. Although unsure of this one.
Dexter Member Since: 12 Jul 2008 Location: Up North Posts: 47 ![]() ![]() ![]() |
[quote="SteveMFr"]
I read about this somewhere before. The FBH and its ECU are one - so the only solution was to remove the FBH and replace it. I'd try to pick up a used unit, tho. Or have a word with Webasto. I'm quite sure they sell individual replacement parts whereas LR sell only the entire unit. |
