![]() | Home > Technical (L322) > Preheater - Battery Failure???? |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
Hi Gav,
kil2508 Member Since: 05 Sep 2010 Location: Wales Posts: 20 ![]() ![]() ![]() |
Hi Ronald
F00syerd00s Member Since: 22 Oct 2010 Location: Aberdeen Posts: 25 ![]() ![]() |
I have same problem with my 1mnth old autobiography. Was using the remote preheater for a few mornings and was getting low battery message when i got into the car. Stopped using preheat but battery died last weekend and required lr assistance call out. Looks like the preheat is too heavy on battery. |
Gav,
Dexter Member Since: 12 Jul 2008 Location: Up North Posts: 47 ![]() ![]() ![]() |
Sorry for my ingnorance Whats FBH stand for |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
Fuel Burning Heater... |
# The Pre Heater is not "too heavy" your battery is just not up to the job, either through constant short journeys or damage - if your battery has fully discharged at all, this damages the battery and reduces its capacity. It could have sat discharged for a while with the dealer. Land Rover/Renault/Mercedes/VW/Audi/BMW have been fitting these for years - I think they know what they are doing. Did you replace your battery after it went flat? Or can we look forward to you posting in a few weeks about spurious error messages on the dash? ![]() ![]() |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
I now suspect the flat battery is/was caused by the FBH turning itself on randomly (2008 TDV8) - I've noticed smoke from the N/S front wheel arch when it's been parked a couple of times.
Does your have a remote? ![]() |
Yes, which was sitting in a drawer some distance away when I've noticed the smoke (off the key-ring to rule out accidentally turning it on). |
slightly of topic, i tend to only do short journeys so can the fbh be switched off to save fuel.. ... - .- -.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
could you pull the fuse? Ian |
But it wouldnt save you fuel - because your engine would take longer to heat up therefore burn more fuel for longer. One of the reasons for the FBH was to reduce emissions - due to the reduced warm up time. ![]() |
that was my first thought but will that do any harm or will it stop something else working.. ... - .- -.
