![]() | Home > Maintenance & Mods (L322) > How to change bulbs in the roof courtesy lights |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
If you pull out one of the black louver type vents behind the switches for turning on the map light you should be able to put your finger in and push out the unit that holds the bulbs and switches. |
Hope this helps.
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
You can't fit LED bulbs as there isn't enough room. What I did was buy some normal bulbs but ones with blue glass so they appear white when on.
I have LED's fitted in all my internal lights, as do others I'm sure. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I have all LED in the interior 2015 4.4 AB
Which type of bulbs are you chaps using.... ?? |
I bought a few of this style which I used in the doors etc....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
most use these type, very cheap from ebay..
Can't see how you could use them..... ??? Not on the little roof lights anyway... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
The roof console is held on by 3 (maybe 2) screws in the sunglass holder. Removed these and the whole unit can drop down. |
eBay Item No. 311698842066 ebay number for the kit i bought , i think they are the same as the ones in your picture. only bulbs that didnt work , were the wing mirror puddle lights which i sourced elsewhere 2015 4.4 AB
Rafterman Member Since: 27 Oct 2014 Location: Sale Posts: 149 ![]() ![]() ![]() |
Lots of stuff on you tube re fitting LEDs on l322 The worst thing about being retired is you miss out on all the bank holidays |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Cheers guys, popped the little square panel out from behind the light unit so could get my fingers in and release the light.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
The owner's handbook instructions for removing the light panel is wrong. It tells to lever from the end. Don't! Do as the workshop manual says and lever from the rear. Once you've popped it out, you'll see why. It is not designed to be removed from the side. Ditto the tailgate lights.
Nope, the hole is too small - I tried them today. I did get them to fit after modifying them but they aren't that bright. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
