![]() | Home > Technical (L322) > ABS sensor. Have I been an idiot |
| Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105
So replaced the right rear abs sensor over the weekend and that curred the speed sensor issue for abou 100 miles. However it's now back.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742
I say NONE because the sensor has to detect the teeth and the gaps between the teeth. |
LR supply the grease with the sensor. I didn't use it.
| zarnd Member Since: 22 May 2014 Location: Kent Posts: 459
Is the gap correct? Alex
It's not adjustable as far as I can tell. So I don't know. I'd have hoped so. Current cars:
I'll whip it out again this weekend and make sure all is fully clean again.
