![]() | Home > Technical (L322) > Heated steering wheel operation |
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
Mine has a red LED light up when on. It is a 2006 MY so things could have changed but hopefully that is some help. 2017 5.0 Autobiography Supercharged
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801
a light does illuminate when its pressed... ... - .- -.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864
The switch lights up, but mine is like me, a bit dim !!. G reg 2.5VM Vogue Portofino red 1991- 1999
| Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300
Agree on the dim light post 2010 - can't see in bright daylight. It heats up within a minute or two. 2012 5.0L S/C
| dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158
Good to know. Will need to cup my hands round the button to see if it works if I go back for a second viewing. It was a hot sunny day when I looked at it so probably couldn't see the light by the sounds of it. I'm used to the bright red led coming on in my BMW X5, and same for the 54 plate FFRR I had previously. |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555
Fuse No. 20 in the back of the lower glovebox. Cheers, Greg
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1476
It is a fairly dim light, I think mine changes between pale orange and pale red |
Been back for another look and it works, very dim light though. Should be picking it up on Saturday. Had a look on TOPIx for the options and the mind boggles with some of them, I guess a new post with them may be in order. |
