![]() | Home > Technical (L322) > L322 Timing Chain, what to do. 4.4 M62 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Delayed response ..
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Wot holy chicken ( |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
hi
Motor does not have to come out. but the front of the car does. (radiator etc.) Saint V8 has done a very good job on this in the wiki. |
hi
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
If you look at the top of the page under the Blue fullfatrr.com logo you will see wiki in red font (RR wikipedia). Do yourself a big favour and read up as much as you can to get a good insight into your vehicle. Lots of invaluable info and remedies all in one place
thanks, found it |
A loud noise sounds like timing chain guide failure which if you drop the sump you will probably find bits of broken plastic from the guide. The rad doesn't need to come out there is stacks of room when the front of the engine comes off. It's a long job to do yourself and you need timing tools which you can pick up for £120 approx. a crank holding tool and very long breaker bar for the crank bolt but will save you a fortune if you do it yourself |
holidaychicken
Negatory, you could stand in there and still have room |
gee
Bolt is normal right hand, have you got yourself a copy of Rave manual which is the best vehicle repair manual ever?
tried to down "2002-2006 workshop manual ..RAVE"
what pc are you using ? |
