![]() | Home > Technical (L322) > L322 Timing Chain, what to do. 4.4 M62 |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 800 ![]() ![]() ![]() |
HP win7 pro |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That should be fine, have you downloaded the manual from the Wiki ?
when winzip was free it was easy to use but now i have paid for it ?????????????
i think windows 7 does it for me, i dont have winzip or anything else but i have used 7 zip in the past.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
Knares, I have a genuine RAVE CD.
hi, thanks, will give it a couple more goes first |
this guy locks the crankshaft by putting the locating pin in the flywheel. Then undoes the crankshaft bolt. RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
He must be bonkers , the starter ring is not made of strong stuff and the 5 mm diameter pin is a little on the small side.
how did you go Josho RR 2005 4.4 petrol
