Home > Technical (L322) > Another reduced performance!
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Hi all,
Wife used the FFRR today and I get an irate phone call when she is on way home. Reduced performance on dash and 50 mph.
I told her just to keep going and I'd have a look when she gets home.
I have just plugged in the IID tool to read codes, there is one triggered yesterday which I'm not sure of (in the attached image)
When I started the engine it had cleared itself, I read the faults as I said, cleared them and took it for a run, giving it lots of abuse, read faults again and nothing listed.
I've read a lot of the reduced performance threads and have somewhere to start tomorrow with split hoses.
Anyone got any ideas, advice etc, if so greatly appreciated! The old girl has been faultless since I got her earlier this year.
 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443155 30th Jun 2017 6:54pm
stu
Stupid ipad how many times has it posted code picture..
Embarassed Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443156 30th Jun 2017 6:55pm
You could have just edited the first post rather than making the thread even longer Whistle
Turbo hoses is the likely culprit on a 3.6, but not heard of that being as much of a problem with the 4.4 - though I could be wrong and certainly worth checking them Thumbs Up
This thread is the only other one I remember about the 4.4.
Post #443158 30th Jun 2017 7:08pm
stu
Suitably edited Alistair... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443159 30th Jun 2017 7:14pm
Baltic Blue
Look at the 4 ports on the manifold.
If any are sooty black, check the short rubber connecting hose.
It may be split, but also it could just be loose and need the jubilee clip tightening.
Sorry the pictures are side-on,
Come home Stan... you are brilliant at putting them right. !!! 😂😂👍 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443166 30th Jun 2017 8:04pm
stu
Sorry to be blonde which manifold? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443167 30th Jun 2017 8:05pm
Baltic Blue
The air intake manifold.
Just remove the engine cover by lifting it off. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443168 30th Jun 2017 8:11pm
stu
Thanks for that! The pictures hadn't loaded on my iPad when I looked before all there now.
Going to service the old girl tomorrow so will have a good prod about.
Thanks for your help.. Bow down Bow down Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443171 30th Jun 2017 8:35pm
Baltic Blue
Whilst you are under the front of the car, you might want to check the air change-over valve to see if it is modified.
My 2011 was the old valve and I got "restricted performance " warning.
Mine was replaced under warranty and has been fine since.( 12 months +)
Good luck. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443173 30th Jun 2017 8:48pm
stu
Will do thanks...unfortunately my car is out of warranty so it's all down to me.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443180 30th Jun 2017 9:46pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
We had a problem with the inlet manifold on our 4.4 TDV8 last year whilst in France. It showed itself as a 'Reduced performance' issue. It would initially reset itself if I turned the engine off and on but eventually stayed on permanently. The manifold had actually split and had to be replaced by a dealer in France.
Post #443186 1st Jul 2017 8:28am
just been out and checked mine for POM, it seems that i have the non nut version of the air changeover valve so thats good. Now in terms of the 4 little rubbers.
I seem to remember a post about them being either smooth or having a rib. Mine have the rib. which is the updated part? smooth or ribbed.
They all seem in good order at the moment but it looks an easy job to swap out the rubbers if i have the older ones.
looking at the TSB above it looks like the smooth ones are the newer type? There is nothing that can't be fixed with a hammer😜😜
Post #443187 1st Jul 2017 8:53am
Baltic Blue
NMJ,
I know that mine are the newr type so I will go and have a look in the next hour and report back. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443188 1st Jul 2017 8:59am
For info.... you can see the changeover valve from the top, if you take the engine cover off, get a torch and look down between the back of the fan and the pulleys, it sits, slightly towards the passenger side in that gap, towards the bottom of the engine. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #443190 1st Jul 2017 9:02am
Baltic Blue
Definitely smooth, no ridges.
Part number LR048062. Intake duct, x4.
Cheers.
I was told that the change over valve only moves a couple of mm when it operates and that is why the unmodified type sticks.
It gets dirty from road muck.
I have given mine a squirt of white lithium grease. Easy job. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443191 1st Jul 2017 9:25am
