Home > Maintenance & Mods (L322) > Place your bets
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Place your bets
Oh the wo of owning a range rover
The Car is going into Range Rover Main stealers up here on Tuesday after a couple of problems
1) Started about a month ago with A suspension Fault that only happened every so often as days went by frequency picked up until the point of getting to the end of my road and I get the obligatory BING from the dash , I've had it checked over by the main dealers and they reckon it's either electronic or and air leak and having heard air escaping from under the drivers side I'm pretty sure I know what it is just not where.
2) Driving home tonight cars running fine then I felt it drop in power and Engine System Fault come up on dash and it would only do about 10MPH up hill so I pulled over shut it off and restarted and it appears to be back to normal not that I've had chance to test it fully yet
So any ideas L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #443312 2nd Jul 2017 5:10pm
1. If you can hear air you have a leak, it will either be a leaking airbag or the feed pipe will have chaffed through. There is a thread on it on here. Can be fixed with a straight connector.
2. Before you send it to the dealer for this, take off the passenger side top turbo hose and check it for splits, it will be under the webbing part of the hose. Have a look here for how to get it off http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #443315 2nd Jul 2017 5:41pm
Ivor
Thanks for the Info Unfortunately I'm working for 12 hr shifts for the next week so won't get chance to have a good poke around guess i'll have to swallow a bill and hope it's nothing major Rolling Eyes L322 2008 vogue
Post #443349 2nd Jul 2017 10:21pm
Ivor
Well got the chance to dive under the hood tonight as it's a nice evening and it took me ten minute to whip off the intercooler hose give a wash and locate the problem,as you can see from the photo it split underneath in front of the throttle body never would of found it had it not been for NorthernMonkeyJones thanks you where a real help
 L322 2008 vogue
Post #443422 3rd Jul 2017 7:58pm
the tape from Halfords will fix it temporarily while you wait for a hose to arrive Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #443424 3rd Jul 2017 8:04pm
Ivor
Had a roll of gorilla tape in the garage just need to pop down and get a replacement L322 2008 vogue
Post #443445 3rd Jul 2017 9:23pm
That'll do it too. Very Happy There is nothing that can't be fixed with a hammer😜😜
Post #443456 3rd Jul 2017 10:16pm
Ivor
Well it's been into the main Dealers for two days now so i've had the pleasure of driving around in new disco sport and for princely sum of £110 they have come back with diagnoses
1)Air reservoir porous needs replacing £390
2)Air compressor dead due to running all the time (no Surprise) £900 for an uprated one
They have the go ahead for the reservoir as I did have a look at it and it's rusted to hell which usually mean nasty bolts to get off and much knuckle bleeding
The Air compressor I have said I'll sort that out myself
I was looking at these two
https://aerosus.co.uk/land-rover/range-rov...YMEALw_wcB
https://www.britishparts.co.uk/products/85...-RQL000014 L322 2008 vogue
Post #443760 6th Jul 2017 8:35pm
Give Dan a shout on the compressor, he can get oem parts as well as LR. Worth a shot and will no doubt be cheaper than the dealer. There is nothing that can't be fixed with a hammer😜😜
Post #443776 6th Jul 2017 10:49pm
Mr Tee
Got a compressor from dan last year, whilst pricey, no where near that amount !
Post #443783 7th Jul 2017 6:42am
Odd that later model reservoirs are going rusty... .
Post #443787 7th Jul 2017 8:59am
Ivor
I should be getting the car back today and i'm not saying I don't trust the techs but i'm going to check the relay and fuses before I order as I've had them diagnose a dead fan before now and it turned out to be a switch L322 2008 vogue
Post #443792 7th Jul 2017 10:10am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I believe the early l322 had an alloy tank then JLR started using steel resiviors which are common for failing
Post #444058 9th Jul 2017 6:33pm
Bigald
turbo hose
Thanks to northernmonkeyjones just had car in for service they plug it in and said looks like you need new turbos asked if they checked hoses yes all good so when I got home hoses off right hand side 1 split gorilla tape and no more engine failure and limp home mode once again thank you everybody
ps sorry to hijack thread
Post #444930 18th Jul 2017 6:22pm
