Home > Technical (L322) > 2004 - 2006 Bi-Xenon Help Required
if it helps you tracing the feed wires then on mine the halogen main only gets a 10 volt feed when the main is on..hope that makes sense.
Post #45511 11th Jan 2011 8:40am
Martin
Site Admin
I wouldn't rely on the the parts catalogue descriptions to confirm the technical spec of the lights.
Microcat actually lists Halogen, Xenon and "Adaptive Bi-Xenon", with supercession to common part numbers for all 06-09MY.
If you take on board and accept the rest of the technical information and do not solely work from Microcat as your reference, then the lamp listed as "Xenon" in Microcat should actually be listed as Bi-Xenon.
Obviously not being in possession or vicinity of the units or any photos of connections, pinouts etc then I'm working blind, I'm happy to be proved wrong but so far we only have your assumption from Microcat that the standard xenons are not bi-xenon. This goes against this post:
mattstevenson2005 wrote:
my car has the 2007 Bi-Xenon NONE adaptive headlights fitted
According to you Dan these type of headlights don't exist! Wink
Non-NAS Non-adaptive Xenons should only have 9 pins, these functions:
Side
Side Earth
Dip
Dip Earth
Main
Main + Indicator Earth combined
Indicator
Xenon Shutter
Xenon Shutter Earth
Non-NAS Adaptives have 4 additional pins for the adaptive:
Ignition 12V+
LIN bus
Adaptive Motor Module Earth
Corner Lamp Earth
However I kind of get the feeling you don't want my input here, but I am only trying to help Sad
Post #45526 11th Jan 2011 10:33am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
its very easy to tell if it has the shutter, if there are pins in the 5 & 6 socket then you have the shutter.
Matt
Post #45605 11th Jan 2011 8:56pm
dan_uk_1984
Matt
Car is at the mech's having the tow bar fitted tomorrow - but from memory 5 & 6 are empty on mine? Confused
Post #45629 11th Jan 2011 10:36pm
Martin
Site Admin
Did you get anywhere with this Dan?
Post #46486 18th Jan 2011 4:43pm
dan_uk_1984
Yup, done.
The lights I took off did not have pins 5 & 6, the part number did not make sense, started with numbers rather than XPC? or LRO. Anyway it didn't conform to a LR part number, all very odd. As far as I'm aware they don't do pattern parts for the lights? I did find one link to my part number, but that was a Japanese site...
Anyhoo, makes ALL the difference when driving at night, especially in the rain. All in all, I sold my old lights for £110 more than the ones I bought too.
Big thanks to the guys who helped with the pinnouts & diagrams & moral support!
Post #46503 18th Jan 2011 6:27pm
Martin
Site Admin
Grand Thumbs Up
Post #46505 18th Jan 2011 6:29pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
maybe helpful
http://l322.com/HEADLIGHTS.html XJC, RRV8, Series1 86 and 107% of real pleasure
Post #46638 19th Jan 2011 5:01pm
dan_uk_1984
delsilencio wrote:
maybe helpful
Thanks,
Although there is little info on how to actually do the conversion there. Just how you can buy loads of stuff from him....
Post #46639 19th Jan 2011 5:26pm
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Dan
For some reason my shutters have stopped working, so I only get the halogen on main beam and not the bi- xenon
They were working previously, however one night a couple of weeks ago the shutters stuck in the open position and would not turn off untill I turned the ignition off then back on again
Any ideas Sad
Post #59139 6th Apr 2011 9:15pm
