![]() | Home > Technical (L322) > Air Con |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
It will decline slowly, so it was fine yesterday I'd check the switch/wires ensuring the pump clutch is working first. |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
I do hear the clutch engage when i press the air con button on and off.... |
Does the clutch stay engaged?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
any reputable re-gasser will be able to do a leak test to see if or where your system is leaking... ... - .- -.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I had a leak from a pipe the runs along the drivers wing.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Paul - same as mine, the pipe arrived from Duckworths this week and is currently on the table, will probably go onto the car tomorrow evening!
