![]() | Home > Technical (L322) > STRANGE PROBLEM |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
check your connections to the battery. Mine did similair recently and was confirmed when i could remove it by hand easily. Ended up having to replace the negative lead and it fixed it.. |
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 ![]() ![]() |
ive checked them mate and they are all tight. but i think its something along them term. i will check all the earths to body and chassis etc tomorrow Current. FFRR Vogue. TD6 Java black.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Ignition key on its way out? John
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
That was my thought weggie |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
I had this its the control module at the bottom of the key barrel has to be done by a dealer as has to be coded to the car, its about £60 for the part plus the labor. |
I did mine on my Td6. No coding was required. Straight swap - once you take the top of the console out.
i think its the switch i had to struggle on trying it a few times this morning Current. FFRR Vogue. TD6 Java black.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 813 ![]() ![]() ![]() |
Had the same problem with my saab and the mercedes , the key is read as its inserted , if the unit is going bad , no kiss kiss no bang bang |
