![]() | Home > Technical (L322) > Yellow light |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Could you fill in your car profile please, then we will know what year, engine and model hou have.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
could be the speed limit warning.... ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
As Stan suggests, the speed limit warning is a yellow arrow - mine is set at 80 in the pic below....if yours is set to 150 it could be down there?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
The default setting is around max150.
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Thanks for the reply's, I found it while in north wales. It was the set limit, for some reason it was on 156. Why I didn't get one of these monsters years ago I will never know.
btw you can switch off this function in the dash menu ... ... - .- -.
Thanks Stan, That is how I found out that was the light |
