![]() | Home > Maintenance & Mods (L322) > BMW M62 timing tools |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
tie wraps can be used to hold the timing in place on some chain engines , just saying |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Not with the vanos set up, it is far, far more complicated than a conventional set up, it's just about impossible to do it without the correct tools...
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Hi Matt,
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2254 ![]() ![]() ![]() |
You can shock the fan off with a large spanner and a hammer - did it on my 535 which is the same engine basically...
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
You can do that on the M62 engine as long as you never want to drive it again ![]() I had a used set of locking tools and even with those it was a bit scary as they were a little baggy |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I made the fan pulley holding tool from a diagram posted on here. My welding is pretty dodgy but it held up.
