Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 19 of 27 <123 ... 181920 ... 252627>
kansanbrit
United States
Re: Climate Seats Fixed
TeeMyob wrote:
What did you use to get that fault code please?
Looks like he used a GAP IID to me.
www.gap-diagnostic.com
Post #612326 11th Nov 2021 6:19pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
MarkA wrote:
Will follow with interest as my drivers seat also doesn't heat, just assumed my fat arse was too heavy.
If you find any solutions please update the thread.
Me too. Definitely a 'Big End' problem ! Rolling with laughter Forty years of progress. 1972-2012
Post #612709 15th Nov 2021 1:09pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Getting that kind of weather now.
Even if `I could swap over bits from passenger seat id be happy
Post #613353 21st Nov 2021 8:35pm
Fox889
Bite the bullet, get a new pettier unit from Duckworths on here & do the job proper Smile 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #613367 21st Nov 2021 10:08pm
TeeMyob
Thanks
Duckworths ?
Post #613368 21st Nov 2021 10:17pm
Fox889
Site sponsors & they offer members a discount. Great service as well. Check one of my threads about 12 months ago, I had the same problem & cured it with a new unit. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #613370 21st Nov 2021 10:35pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
We still have some repair kits in stock. Not many left. Will be placing an order soon.
FFRR members get a discount.
Post #613371 21st Nov 2021 10:52pm
Charmer
I used one of the kits provided by JNC and did the fix myself. It took me about an hour to disassemble the seat back, remove the failed unit, change the peltier cell and corrugated housing, replace the repaired unit and reassemble the seat back.
If I can do it, I am fairly certain most on here also could!
Still working a few weeks later and I am feeling the benefit every morning! Very Happy
Post #613372 21st Nov 2021 11:23pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Do you provide a kit that replaces the peltier cell on the seat base and backrest? Both my front seats don’t work at all.
Thanks
Post #613391 22nd Nov 2021 9:56am
JNC
I’ve never seen the base unit fail.
The seat back ducting splits and causes the cell to overheat.
The system shuts down and prevents that entire seat working.
I’ve not seen the passenger side fail but of course it’s likely.
A good way to tell without diagnostic tool is to turn on the heat and feel the fan under the seat.
If it runs for a few seconds and turns off it usually means it has gone over temp. A sign the cell has failed.
The heated/cooled system for that seat will cease to operate again until an ignition cycle.
Post #613392 22nd Nov 2021 10:04am
kansanbrit
United States
Don't if anyone has said this before but the same unit is used in 09-15 Jaguar XF seat.
Post #614412 1st Dec 2021 7:25pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
My seat back heats up, but not the base. Seems to be the opposite to everyone else? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #614454 2nd Dec 2021 2:58pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
It could be that the filter is blocked?
Post #614457 2nd Dec 2021 3:47pm
28capridave
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Mine does exactly the same the base refuses to heat up but if i turn just the back on it works a treat have checked the filter and its clear the cooling works really cold its a 2012 model
Post #617286 22nd Dec 2021 8:55pm
JNC
Does the system shut down if both parts are turned on?
Or the back still works but not the base?
Post #617292 22nd Dec 2021 9:59pm
