Home > Technical (L322) > Struggling to start
Stonie110
Struggling to start
The car turns over for ages and then coughs and splutters to life and kicks quite a bit of smoke out
I’ve replaced fuel filter
Battery is good
Both fuel pumps are working correctly
Glow plugs and relay checked
It’s not showing any fault codes
Post #456070 4th Nov 2017 5:09am
can you fill in your car profile so we knew what you have... ... - .- -.
Post #456074 4th Nov 2017 8:26am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
sounds like glow plugs are goosed so not pre-heatin the derv up pal , id try new ones before doing anything else as you have to rule them out
Post #456109 4th Nov 2017 11:54am
Stonie110
Glow plugs have been tested and the glow plug relay has been tested
Post #456130 4th Nov 2017 3:38pm
nino_nino
Stonie110,
if glow plugs and relays are OK, pumps are working, new fuel filter - next suspect must be injectors.
I use 2T oil (1/2 litar per tank) and it works cleaning and lubricating the injectors.
Post #456134 4th Nov 2017 4:02pm
Stonie110
It is going in to garage next week for injector tests.
Post #456137 4th Nov 2017 4:21pm
If it's a TDV8, read on......
Or, as happened to me after replacing the fuel filter, I had to bleed an air lock in the fuel system.
Take the top plastic cover off the engine and as you look at the engine from the front, look dod what looks like a bicycle tyre valve. Press it down until fuel comes out and Bob's your auntie! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #456160 4th Nov 2017 7:09pm
Stonie110
It’s the 3.0 td6 engine
Post #456162 4th Nov 2017 7:37pm
lesmcm
South Africa 2003 Range Rover HSE Td6 Atacama Sand
Check the HP pump pressure relief valve on the back of the pump with a diagnostic tool the lp pump should read 3 bar the HP should be about 300 bar.
Post #456163 4th Nov 2017 7:48pm
Stonie110
It has been plugged in and both pumps are working fine
Post #456172 4th Nov 2017 9:08pm
