![]() | Home > Technical (L322) > Problem Part 1 (Electrical) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
it might be as simple as the battery not giving enough power to get ALL the ecu's going...how old is the battery, if over 3 years then i would think about replacing it. ... - .- -.
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 ![]() ![]() ![]() |
Hi Thanks for the reply. If this is the case why does the system re-start after the fuse is pulled and replaced the battery voltage will be the same and then why does the system not re-start when the engine is running and battery/system voltage is at maximum? Surely if a battery can supply enough amps to start a diesel engine in the winter then a few ecu's should be no problem unless it is a voltage issue and the voltage would not change between pulling and re-inserting a fuse. I can only ever get the system to re-start (when down) by pulling and re-inserting the fuse. ![]() _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel Last edited by Captain Slog on 24th Jan 2011 8:33pm. Edited 1 time in total |
could be [like a pc] you're rebooting the ecu which in the first place didnt have the oooophh to get going..only a theory mind. ... - .- -.
