Home > Technical (L322) > L322 3.0Td6 03 EGR Blanked fuel consumption
Page 2 of 3 <123>
Paul thornton
I'm about to order one of the egr delete kits. Seen a few on eBay for around the £25 mark.
Don't suppose they remove the egr thermostat as well do they?
Post #460620 12th Dec 2017 7:33pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
my blank kit has just arrived , I think it for the EGR only pal , not the cooler
Post #460756 13th Dec 2017 7:26pm
Paul thornton
Which one did you get?
Post #460787 13th Dec 2017 10:08pm
wayneg
The egr Delete is that, deletes the egr. If you want to remove the cooler/ thermostat assy you need the blank plate for the exhaust and also 2 caps for the water outlets ( I think these are 15mm) https://www.aliexpress.com/item/cheaper-sh...eLevelAB=0
Picture curtesy of Harlie AULRO
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #460910 15th Dec 2017 7:25am
bembo449
the 25 quid one off ebay pal , the one with the black n yellow warning style emblem Wink
Post #460933 15th Dec 2017 3:22pm
bembo449
so your pic wayneg , shows the 2 15mm blanks , yes ??
Post #460934 15th Dec 2017 3:23pm
wayneg
yes, as I say I think they are 15mm, don't hold me to it 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #460997 15th Dec 2017 11:58pm
bembo449
ok pal , now ive seen how its done I intend to remove this while I blank the EGR off
Post #461018 16th Dec 2017 10:28am
wayneg
A few in the UK don't bother with the fan so as you are up north you should try running without it once the cooler gubbins is removed. There has got to be a fuel saving and noise reduction with it gone. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #461019 16th Dec 2017 10:34am
bembo449
ive just fitted my blanking kit for the EGR , cooler end of the pipe was already broken off Rolling Eyes he defo sounds quieter but that could be cos the cooler pipe is now sealed ? will run about a bit after work and see if there is a noticeable performance change , scoped out the cooler removal while I was there , looks easy enough especially after the pic you posted wayneg
Post #461257 18th Dec 2017 2:58pm
Paul thornton
Hi bembo449,
Was it the one with the extra blanks or the one that connects up like a normal egr?
Thanks
Post #461354 19th Dec 2017 12:12am
Beemergriff
I blanked mine a couple of months ago, as I had fault messages.
With EGR in place I was getting 22-23 mpg and with it blanked I am now getting around 25 mpg and I don't drive with economy in mind Smile
Not a great improvement, but every little helps. My car has done 210k and regularly pulls 2t on a trailer, when consumption drops
Also had error message on No.1 injector - checked connections, lots of WD40 on leads and OK for a couple of weeks.
Replaced entire injector harness, and no problems since.
Post #461415 19th Dec 2017 1:34pm
bembo449
Hi bembo449,
Thanks
yes paul , the full kit , I didn't need the EGR blank discs as I removed the cooler completely , I suggest anyone with a td6 remove this part , car is smoother ,quieter , seems a little more eager and the heating has also improved quite a lot ! this was my initial reason for removing the cooler but the side effects are very welcome Very Happy Very Happy
Post #461520 20th Dec 2017 2:28pm
Paul thornton
Difficult to do or straightforward?
My temp gauge rarely goes past a quarter so eliminating the egr cooler wouldn't be a bad start
Post #461531 20th Dec 2017 3:32pm
bembo449
pretty straight forward but I didn't mind working with the fan in situ Paul , long as you have / borrow a decent 1/4 drive socket set ? you will also need a T45 torx and some pipe clamps / pincer mole grips pal , the only other thing is the blanks for the cooler water pipes , I cut down a long bolt into 2 pieces , the type where the threads are only at the very end , needs to be 17mm diameter for a snug fit the jubilee clip into place
Post #461532 20th Dec 2017 3:38pm
Page 2 of 3 <123>
