Home > Technical (L322) > Heated windscreen - is it working?
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Anyone know of a way to check if the heated (front) screen is working? Had my screen changed and not convinced the heated elements are working. I'm sure it cleared frost in a matter of seconds last winter
Job was done by National Windscreens, absolutely useless company, had other problems as well and wouldn't recommend them to anyone. Wish I'd left it with the cracked corner Rolling Eyes
Post #458460 24th Nov 2017 10:57pm
put cling film on the screen and try .... ... - .- -.
Post #458462 24th Nov 2017 11:01pm
Lee Marsh
Thanks Stan, I'm not sure how that would work, but can plainly see it's only clearing from the blower at the bottom of screen while the rear screen clears quicker, without any added air.
I'll check fuse tomorrow but unlikely as the dash lights including heated front screen and defrost mode are lit up.
Post #458471 25th Nov 2017 1:00am
andygts
Get up early, pretty sure most places are forecast a frost overnight, mine is lightly covered now.
or
boil the kettle then place it in the car for a few minutes, all the windows should mist over pretty quick as the warm air hits the cold windows, turn on the heated window and you should see the lines appear and the screen clear. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #458472 25th Nov 2017 1:01am
Lee Marsh
Yh thanks mate, went out there few minutes ago, it's frozen but no lines vertical clearing as there are (horizontal) from rear screen.
No doubt they'll (again) deny it's anything to do with them Mad
Post #458473 25th Nov 2017 1:06am
AJ Johnny
I had a P38 screen replaced once, before I realised what he was doing he put a socket on the earth stud below the screen without a spanner on the locknut and broke the stud off. He said “those are always weak”.
Post #458484 25th Nov 2017 9:36am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
OOOO had ours done Tuesday by Autoglass, guys seemed decent enough and Pilkington glass was fitted, and am about to start it up in the frost....
Post #458490 25th Nov 2017 10:08am
ohuntsman
Rats! in the time it took to pour a coffee the sun beat me to it!!
Post #458494 25th Nov 2017 10:44am
Lee Marsh
Whereabouts AJ are the electrics below the screen, and are they visible? Guessing the scuttle needs removing...
Post #458542 25th Nov 2017 11:53pm
You can feel the screen get warm with your hand.
When my screen was replacd, they used the wrong connector so only the wiper area got warm - I got autoglass back out and they fixed it, but the guy tested by putting his hand on the glass - nothing more sophisticated than that.
Post #458547 26th Nov 2017 4:58am
Lee Marsh
Guys from National Windscreens had a look and suggested all connected up ok. Problem is, it still doesn’t heat up. Theyve said ‘it just takes a long time and doesn’t get very warm’. The connections are in the drivers front A post and is just regular type clips, no studs and bolts etc.
Maybe the screen is a bit duff. Certainly not Pilkington's
Post #458959 29th Nov 2017 10:23pm
AJ Johnny
Apologies Lee, I missed your question. The P38 had a stud welded to the outside of the body on the centreline of the car, immediately below the windscreen. Remove the trim below the windscreen and it should be obvious. Two leads came off the windscreen and both bolted to the stud. After the stud was sheared off the earths were self tapped to the body which I wasn’t overly happy with as the screen pulls a reasoable current.
Anyway, if the positive connections you found are getting power when switched then look or test for a good earth connection for the screen elements.
Post #459549 4th Dec 2017 1:41pm
Rob99
That's rubbish, a genuine heated windscreen will start clearing the screen in a few seconds. I suspect they may have used a cheaper screen. Can you see the lines of the heating elements? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #459557 4th Dec 2017 3:31pm
Lee Marsh
Got them to change screen, as not heating up as previous (original) screen. Hasn't been cold enough yet to check if any better. Not going to hold my breath on it tho. They again used a NordGlass.
Yes both had elements Rob
Am sure it's getting power AJ.
Thanks guys
Post #461835 22nd Dec 2017 7:00pm
