![]() | Home > Technical (L322) > ELECTRICAL WIRING TECHNICAL QUESTION RHS Repeater |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
So this failed on the MOT, it stopped working when I tried to jump the car on the wiring after being locked out - the wires melted into each other.
So the Repeater is already wired correctly - it just doesn't work.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
From what you describe it would seem so. |
Can I buy any LCM? Do they have to be coded to the car? |
A new lcm will require to be programmed to your car, a used one will put a red dot on your instrument panel indicating the mileage and vin is incorrectly recorded.
Thank you nicedayforit.
Good to hear you got it sorted, definitely worth getting your lcm refurbished for what it costs. |
