![]() | Home > Technical (L322) > Electrical problem with 2011 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Is the battery flat? |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Hi Paul,
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
Could also be an alternator problem, if the battery was flat.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Should be approx 14.6 |
Boy! you guys are good!! Thanks! Will check voltage. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I believe that the car has smart charging ecu. so depending on the need it will charge from 13.8 to 14.6 V it is fuel saving thing. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Yep 13.7 to 14.6 give or take .1 |
Just installed new battery! Everything back to normal!! |
Excellent news |
