Home > Technical (L322) > Intermittent headlight failure
Zain
Since the cold weather has set in i keep getting an intermittent single headlight dipped beam failure. Sometimes its only the passenger side and on other occasions its only the drivers side. I then need to switch off ( and then on) the light switch a few times for the dipped beam to come back on. The dash message comes up as either "check front light" or "check dipped beam". There is no consistency as to which side the headlight fails or to the associated message. All this has happened a few times now since the cold weather has set in. (it was fine all summer).
Ive read up it could be either the ballast module or igniter and to change them over to see if the fault follows the part. However i seem to have the headlight failure on both sides - albeit individually at different times. So any pointers as what seems to be causing this issue?
Post #458986 30th Nov 2017 2:25am
Dolphinboy
Lcu?
Post #458993 30th Nov 2017 8:30am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had this on the 02-05 square headlights, and never worked out whether it was the ballast resistor or the ignitor. First one side went and then the other.
I found it was cheaper and simpler to solve the problem by buying a complete light unit off eBay. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #458999 30th Nov 2017 9:16am
Balloonengineer
I had this and solved it by replacing the lighting module
http://www.ebay.co.uk/itm/Xenon-HID-Headli...2749.l2649
Cost was £38 brand new and takes 5 minutes to fit. Its behind and below the nearside Headlight with 3 torx screws.
Remove the air duct first and its easy. I think I did a little write up on a previous post.
Best wishes
Glen
Post #459021 30th Nov 2017 11:37am
