Home > Technical (L322) > Cold Coolant temp, cold blower, m62 4.4 V8 Petrol
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Strange one because normally this runs hot....
Since the cold snap the FF has taken some time to get up to temperature and blow warm air.
Pulled out centre vents and fixed my centre console cool warm vent roller which was stiff. Stil cold.
Hooked up fault reader and the coolant temp reads 75 deg max and rad temp 35-40 deg. Normally I'm in the 90s for coolant and 50s for rad.
Any suggestions? It would be nice to get some warm air again!
Post #460674 13th Dec 2017 1:08am
Sandyt
Check that the bottom hose is getting warm - could be the thermostat is open and or the electric auxiliary cooling pump is not working (If you have one fitted not sure ) also check each side of the rad is getting warm
then if all that lot is ok then it could be the fan is stuck on
(the viscous one )
Post #460680 13th Dec 2017 6:25am
ohuntsman
Thank you Sandy - no fault code on the auxilary coolant pump.
I'll do a paper test on the fan - the coupling is only a year old so I should be good
Crappy thermostat sounds likely so will check the bottom pipe - am I looking for it to be warm or cold? most of the pipes just feel cold!!
Post #460720 13th Dec 2017 2:08pm
fisha
Likely an open stat. Fit a lower temp one if you're going to be changing it ( plenty of threads on here)
Even if a viscous fan is stuck, it shouldn't overcool cause a working stat should limit the flow through the rad to keep the engine up at temp.... Which isn't the case here. ... Implying the stat is open. (Imho) V8 or else ...
Post #460754 13th Dec 2017 7:08pm
ohuntsman
Thank you Fisha, I have the lower stat in the box ready to fit Smile
Post #460758 13th Dec 2017 7:51pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
+ 1 on the stuck thermostat 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #460759 13th Dec 2017 7:59pm
ohuntsman
Opened her up and the stat wasn't stuck open but there was a lot of scale when I flushed and the stat was corroded on the outside.
Unfortunately I couldn't get the lower mod to work but it is now working well with one from Euro Car parts
Post #461867 22nd Dec 2017 9:43pm
