Home > Technical (L322) > Lost cons to mid can
Sandyt
Morning all my l322 has lost coms was displaying lost sync with mid can
Also immobilised and won’t start tried battery reset no good
Now lost all coms with IId tool
Help please can’t even get in to read faults or restore ccf
Post #463991 10th Jan 2018 1:24pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
It sounds like a power issue to me. Check your battery voltage. Do you get dashboard lights on. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #464003 10th Jan 2018 3:02pm
Sandyt
Right update battery with booster pack on showing 15v and 12.5 with ignition on Iid tool connecting but still saying no connection to Mid Can . It will read faults but when I clear them it says update failed. Tried CCF restore went through the whole cycle and said update failed - anyone with any idea on how to restore comms to mid can
Post #464025 10th Jan 2018 6:08pm
Grofus
Might be be worth an over night charge. 12.5 v is ok but not great. What is Mid Can? I'm guessing Canbus but it is a guess. Suggest an email fired off to Gap. Glad progress is being made. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #464035 10th Jan 2018 7:02pm
Sandyt
Right problem solved had a landrover electrician come over identified a broken wire behind fuse box on passenger side replaced and all back to normal Thumbs Up Thumbs Up Thumbs Up
Thanks for the input
Post #464079 10th Jan 2018 10:26pm
