![]() | Home > Technical (L322) > Glove box fuse access |
Roadking Member Since: 03 Sep 2017 Location: West of Scotland Posts: 38 ![]() ![]() ![]() |
Started fitting a dash cam today and got stuck at the point where I was looking to access the fuse box in the passenger glove box. The handbook and videos I've seen show the right hand stay being unclipped (which I have done) and no mention of the left hand stay. In any event, I can't see how that would unclip.
Greg,
Got it!
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Ok so it's the glovebox you want to drop. The stay has a barbed end so open it as normal and it hangs on the 'stays'. Then pull the top end of the stay towards the opening of the box. I think that's right for both. Only proviso to this is that I'm saying this from memory. I can check mine in an hour or so. Cheers, Greg
Thanks for that. I got it when I went out to take photos. |
I didn't know you could do that. Does it apply to all models/years ? .
Not sure. Do they all have a lower glove box? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
Bit of a thread resurrection….. my glovebox seems to want to drop fully down if you put anything in it. I studied the pics above and deduced that the hanger arrow bit that you move to get it in a position to access the fuses that goes through the hole, isn’t staying fully to the right and springing back a bit, hence not much purchase.
the rod thing that has a hook / stopper - just bend it out a bit Cheers, Greg
It seemed to be made of plastic… was a bit wary of doing that. Will investigate further.
bend it gently , IIRC towards the centre console, making it a little past when it will "insert" into it's slot. then just help it into the slot Cheers, Greg
