Home > Technical (L322) > Part Numbers Request Please
green-oval-nut
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
Hi, I have a 2002 52 Range Rover 4.4 Petrol. I have bought a brand new oil cooler, but want to buy new oil cooler pipes for the gearbox,and any other associated parts for the job. Please could someone tell me what I need please and the part numbers?
Cheers
Post #464493 14th Jan 2018 4:51am
GraemeS
Australia
According to 2012 Microcat for 2002 ZF 5-speed for M62 B44 4.4 Petrol V8
Tube (w/o Banjo fitting) UBP000180
Tube c/w Banjo fitting, bolt and top washer UBP000161
Ring (O-ring?) PYX100230 (bottom seal for Banjo fitting)
Both tubes shown with a flexible section.
Post #464494 14th Jan 2018 6:40am
holidaychicken
Find part numbers here as you will need o rings from memory and I changed my thermostat and holder and banjo bolts when we rebuilt my transmission so everything was new.
Dan at Duckworths can get you a better price I’m sure.
http://lrparts.ru/engl/
http://www.island-4x4.co.uk/cooling-heatin...mp;sort=3a
http://www.island-4x4.co.uk/gearbox-transm..._3191.html
Post #464502 14th Jan 2018 9:15am
green-oval-nut
Thank you
Post #464595 14th Jan 2018 10:57pm
green-oval-nut
Will I need to replace ATF fluid? And do I need more than 1 O ring? Cheers
Post #464604 15th Jan 2018 12:19am
holidaychicken
I can't remember exactly but if you follow the procedure through in Rave, - download from the wiki it will tell you what to remove / replace . http://www.fullfatrr.com/wiki/Main_Page
Also have a look at the microcat site i linked as that will show you exploded diagrams and give you part numbers for all the seals and washers etc.
Are you replacing the il cooler because you have been getting the overheat strategy and message ?
Post #464608 15th Jan 2018 2:16am
