Home > Technical (L322) > Water / Condensation in Front Headlamp
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
A couple of weeks back following some heavy rain, I drove at around 20mph through about 10 inches of water. Somehow it seems that water has managed to find it's way into the underside of the front headlamp unit, and 2 weeks later it's still there, showing no signs of evaporating. (See photo attached below)
I personally won't be able to fix it (as anything I touch tends to break) but I was going to get my Main Dealer to do it next month at time of service....... To avoid me getting robbed, please can someone give me an indication as to whether or not this is repairable (I would guess by opening the lamp and drying), or will it need a new a new unit? In 3 years of ownership, this has never happened before!
If repairable, please can someone let me know roughly how long this should take to fix, so I don't get massively overcharged for labour by the main stealer?
Many thanks
Post #464541 14th Jan 2018 5:27pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
It's relatively easy to remove the headlamp - take the front grill off (3 screws) and then undo the 3 screws that hold the lamp in place. Lift out and disconnect the plugs remove the caps on the back of the unit where you access the sidelight bulbs and drain the water out from there. The headlight should be sealed but if you've got a cap missing that would be your possible way in for the water.
Post #464582 14th Jan 2018 8:45pm
NobbyC
Lamp covers number 10 in diagram - open and drain.
Post #464583 14th Jan 2018 8:57pm
aja500
Now you've given me such a detailed solution, I've got to have a go haven't I....... Thank you for taking the time out to send me this NobbyC, it's very much appreciated.
All the best
Allister
Post #464601 15th Jan 2018 12:00am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Does it clear when the lights have been running for a while? Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #464641 15th Jan 2018 1:49pm
aja500
Hi Alex
No I'm afraid not, it seems that the sheer pressure from when I hit the water, has somehow managed to push it into the unit and now it can't get out - The heat from the lights also doesn't seem to be burning it off. There's no fluid or moving water as such, it's appearance is almost looks like condensation.
Allister
Post #464726 16th Jan 2018 12:45am
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
So remove as above and use a hair dryer to dry it out, then leave it overnight at room temperature!
Worked for me with one of my rear light Thumbs Up 2014 vogue se
Post #464745 16th Jan 2018 10:49am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I had an old headlamp (2003 model) which had a broken bracket so needed a new unit. There are a number of metal clips which hold the headlamp glass onto the casing, if you are very careful you can prise these clips off and remove the glass from the unit itself. If you can do this it may be worth running a bit of clear silicon sealant around the glass when refitting it.
Post #464756 16th Jan 2018 1:31pm
aja500
Cheers guys, will investigate this weekend
Post #464821 16th Jan 2018 10:51pm
Stuart-
I'd be doing this. Easy even for an amateur bloke.
A dealer will just tell you that you need a new headlight. Those blokes are fitters not mechanics. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
Post #464830 16th Jan 2018 11:27pm
aja500
I know what you mean about them being fitters...... That's my fear, they're all sharks, they'll just do what's easier and more profitable for them.
Also there's obviously not much of an issue with the headlamp unit itself, if there was even a small air inlet, the condensation would have cleared by now - It was obviously just sheer pressure that pushed the water through the seal.
Post #464838 17th Jan 2018 12:23am
