![]() | Home > Technical (L322) > Stereo Issue |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi Folks,
Any ideas folks. Just not sure where to start looking.? Ash
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
what you describe is how the sat nav voice works but yours is without the voice .[does that make sense]
Have you checked for water in the boot? Do you leave the A/C on? |
Well I did check the boot a week or so ago and there was water in there. i do keep the AC on all the time. I dried up the water and no more in there since.
All of the modules talk to each other on start up/turn on. So if you have a loose connection and one module then cant see another - it then wont do its "handshake" until its been turned off and on again. Does that makes sense?
Thanks Dan, Will check for the hole.
