Home > Technical (L322) > Has my fan just died
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
After a faultless 50 mile journey , hopped back in the rangey to find i have no fan ! Tried all the settings but nothing , has my fan motor died ??
Post #469601 21st Feb 2018 7:13pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Do you mean heater fan?
I’d start by checking fuses just in case.
If fuses ok, most likely final stage resistor (FSR aka Hedgehog). Located in RH footwell behind control panel. Needs a bit of contortion to reach, but can be swapped out without much dismantling.
Search for FSR will no doubt yield advice and probably photos. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #469605 21st Feb 2018 7:23pm
steveball
http://www.fullfatrr.com/forum/topic781.ht...eplacement
Good link from Joe90 a few posts down in the link above, which has pictures. Current: 2010 Range Rover L322
Post #469607 21st Feb 2018 7:34pm
Just make sure, then make sure again, you have the replacement FSR properly seated in its locating hole, otherwise you will be replacing it again, in short time Thumbs Up .
Post #469610 21st Feb 2018 8:38pm
mpirie
As Joe mentions, make sure the fsr is seated properly, it is cooled by the fan and if it's not cooled properly, then it overheats and blows, costing you another 50 quid.
You can check the fan hasn't siezed by removing the pollen filter housing and turning the ignition on. That should expose the fan blades and you may be able to tell if it''s siezed or not by turning the blades by hand or by a long screwdriver.
If it's stiff to move, then the likelihood is that the fan has failed.
Good news is it''s a BMW part and costs about 80 quid. Bad news is you need to take the dash/stereo/ventilation out to get to it.
It''s not hard to do, but requires nerves of steel to dismantle you pride and joy to get to the fan.
Mike
Post #469650 22nd Feb 2018 9:21am
bembo449
big thanks for all the info guys , -2 here this morning so was dreading the 40 mile drive to Hull but 2 mins up the road the sodding thing sprang into life ! wtf ? no matter what I did it worked spot on , ruddy cars lol , I wonder if the fan was slightly seized and then righted itself ?
simon
Post #469677 22nd Feb 2018 3:26pm
mpirie
Simon,
If the fan has started working again, I would still suggest taking the pollen filter housing off (2 minute job) to access the fan.
Some judicial spraying of lubricant into the centre of the fan (not the centre of the blade) may help prolong the life of the fan motor.
The bearings in the motor dry out and make it harder and harder for the motor to spin, which in turn, draws more and more current through the fsr, shortening it''s life too.
Mike
Post #469751 23rd Feb 2018 9:24am
bembo449
right ive done as suggested , stripped and liberal dose of lube onto fan axle , just see wether thats the end of it i guess
cheers for all the help guys
simon
Post #469767 23rd Feb 2018 11:47am
bembo449
ive had to order a FSR , fan goes on and off like a tarts underwear
Post #471354 6th Mar 2018 4:28pm
mpirie
Hopefully, that'll be the end of it.
Mike
Post #471380 6th Mar 2018 7:45pm
bembo449
Oh and how wrong you were pal ! The 5 pin connector is pretty much mullered , which is obvs why it failed but it had defo been messed with previously , now i need to locate a decent connector ! Wish me luck
Post #472199 11th Mar 2018 10:32pm
Paul thornton
I'm guessing that's how a lot of them set on fire then?!
Post #472205 11th Mar 2018 10:49pm
mpirie
You'll need it. I remember trying to get a replacement OBD connector......no chance, would have had to buy another loom. Big Cry
Mike
Post #472222 12th Mar 2018 7:43am
