![]() | Home > Technical (L322) > Bong, Bong, Bong...... |
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
Here's a strange one. I got engine management fault, HDC inactive, Parking brake Inactive and Transmission fault ( limited gears).
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Think you have answered your own question. Check the ABS sensors and the reluctor rings for physical condition and positioning. .
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
Can you plug it into any diagnostics ? |
Thanks Joe.
| olliecat2 Member Since: 30 Jan 2018 Location: FLINTSHIRE Posts: 13
A low battery in my own experience can throw up all sorts of false alarms. have you tried turning steering wheel lock to lock to clear the yellow triangle warning |
Yeah, tried the steering lock to lock, battery reset, charging the battery. Pretty sure its an ABS fault on the front right now. Sensor or Reluctor ring. Just haven't had a chance to look yet.
