![]() | Home > Technical (L322) > Can some one give some readings on their 3.0 litre L322 ? |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
have you spill tested the injectors ? I had one leaking off badly , after a refurb the engine was waaaaay smoother |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Leak off test on the cheap
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Bembo449 , I replaced 2 injectors with brand 2 new ones and had the other 4 cleaned and checked not too many kms ago, so I would assume the injectors were ok, but then who knows. |
Reading in kPA
Thanks Joe90, as mine fluctuates I will see what the leak test reveals once my test kit arrives
Fancy |
Joe90, will let me check all cylinders at once so after removing the top cover it should take no more than 1/2 and hour to connect and test all at once. I have another diesel car and friends with diesels so will get shared around.
