![]() | Home > Technical (L322) > climate control problem or not? |
jemj Member Since: 13 Sep 2012 Location: leighton Buzzard Posts: 54 ![]() ![]() ![]() |
Hi guys, I have picked up my new L322, well new to me anyhow. I am over the moon with it but fear that I might have a problem which will mean taking it back for a fix. Before I ring up the dealer I wanted to run this possible fault past those of you that have the later model L322's. here goes:-
Thanks for the feedback. Yes the the max AC does fire up the fans. I thought that this might be the case as the temperature did alter according to the temperature set. I only questioned it because my 2002 model fired up the fans and the LED's noticeably on full auto. It is always good to get info from someone who has one and can put you right.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
My fan speed is a function of available heat form the engine and the requested cabin temp. i.e. if the engine is cold on a cold day the fans don't blow cold air around the cabin but they do increase in speed as engine temp rises. As already said though, they don't get too loud unless max defrost is selected. Bish.
Hi Bishbosh10, yes that is how my 2002 model worked, if high temperature was selected then the fans would kick in once the engine reached temperature but it would show the status of the fans with the LED's around the selection knob. My new one doesn't seem to do this I.E. no led's light up although I have now been informed that the newer models don't illuminate the LED's when in auto mode and the fans seem to be only on very low. Unless someone tells me different, I will take what I have been told about the system and see how it goes.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Sounds about right |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Yep, my 2011 is the same as described in full auto - likewise has made my fiancé wonder if it really is working or not!
In auto mode the speed lights don't light up. They do a fancy thing when you select max defrost as they steadily climb to full power but in auto they are always off. |
