![]() | Home > Maintenance & Mods (L322) > 2007 TDV8 Coolant Leak |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I’m pretty sure the trans cooler is on the driver side behind the bumper. But don’t think it has coolant running to it. The coolant reservoir is on the driver side. Either a code or the plastic container might have a split. ______________________________
That should read hose or container. ______________________________
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
if you take out the drivers headlamp you can get to the narrower hose off the bottom of the expansion tank. On mine it was chaffing and almost leaking. Have a look as that is a common leak spot and its near where you are saying.feel down it and you should be able to feel if its been chaffing. |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
I have the ‘air blast cooler’ on my 2007 TDV8
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Yeah, not just supercharged as my TDV8 has one. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
Unnecessary quote removed
