![]() | Home > Technical (L322) > air suspension problem ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
Did you try lifting each corner (back to wheelarch lift) when if off road height?
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 619 ![]() ![]() ![]() |
Just put fuse back in and dash display said( vehicle lifting slow) but got to off road height ? think a trip to garage might be needed |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
That's probably because all the air had drained from the system. They take a while to fill up again. |
Right got me self an iid tool got rid off historical faults (loads) |
Sounds like you've got a leak to me. |
i know but its a slow silent one |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Check your reservoir under the sill, mine had a piece of wood stuck in it, causing slow leak Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Can only see the bottom of the reservoir but it has wax oil all over it. it may have a leak on top ? just glad i have the iid tool now can keep my eye on every thing. like all range rovers been driving it a couple of days and no problems .......... |
well for some reason its all back to normal for now............................................ |
