Home > Maintenance & Mods (L322) > Replacing brake pipes
Strider
Last year i got 4 advisories for my brake pipes so decided it was time to do. Firstly welded extra angle iron uprights on my ramps. The extensions i made 10 years ago also had a extra uprights added.
I backed my fatty up onto it, luckily this gave me the clearance needed to remove the petrol tank covers (one on each side). I then removed the road wheels and fatty was supported on 4 off 3 ton axle stands.
I won't detail the process as it was almost the same as Joe 90's write up. the only difference was there is a 3 pipe brass inline connection on the nearside wing so i worked from that back to the N/S/F, N/S/R and O/S/R wheels.
The O/side front was the only pipe that went to the ABS block (sited in front of the master cylinder). I also replaced both rear flexable brake pipes.
I flushed the whole system using my Ezee Bleed kit (about 1 1/2 litres per wheel, includes 2 sessions of bleeding the system).
Car went for MOT yesterday, passed with no advisories, many thanks to all brake line Guru's for guidance Thumbs Up
Peter
Before
After
View to rear
Post #479973 2nd Jun 2018 10:53pm
Nice work Thumbs Up .
Post #479989 3rd Jun 2018 9:52am
Paul thornton
Do you pre order these or make them up yourself?
Post #479995 3rd Jun 2018 11:14am
Strider
Thanks Joe,
Much appreciated, it was a bit daunting at first, the hardest thing was getting those bloody tank covers off, like you i did cut the rear lips away but kept the rear fixings in place, refitting was a doddle. Once i got stuck in things flowed nicely. Your "how to post" was a great help Thumbs Up .
Hi, Paul,
No, formed them up as I went along, the R/N/S was one continious line, I formed the mushroom then capped it off
and fed it through from under the bonnet through the existing route and left it straight until I made the connection at the rear, then formed the curves and finally cut it under the bonnet, formed the mushroom and connected up.
This was the same method I did for the R/O/S, would have liked to use a single run but as you can see i had to do it in 2 parts the inline joiner is protected by the N/S tank cover when it was refitted.
When I had finished my thumbs and fingers were hurting like hell but it was well worth doing.
The only one I was able to preform and fit was the F/N/S (see pic). I used the original one as a guide.
Post #479996 3rd Jun 2018 11:41am
