![]() | Home > Technical (L322) > Dash lights dimmer |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773 ![]() ![]() |
I expect the dimmer to be generating a PWM signal varying the ON time rather than being a variable resistor.
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
Thanks, but I suspect a 2012 is probably significantly different to a 2005 year.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i turn mine off at night if on a long journey...
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Glen
If your dimmer control is in the light switch then my guess is that it will not have changed. The dimmer fitted to 1999 D2s were pwm controlled and IIRC D1's were too. |
A tinted ipad screen protector would probably be an answer if such a thing existed??
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Just a point, would the touch screen still operate ok with the additional cover?.
