![]() | Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
I am looking at chopping off the 4 pin connector in the glove box, possibly the folder format on the later USB sticks that JLR send out for map updates could be copied over to a 1394 firewire hard drive, it would still need the NavTeq password ( which I believe the VIN of your car is needed to create the password ) , the Denso unit in our cars prompts you to enter the password ( numbers onyl) , does anyone know how many numbers the later USB stick maps use on L405 cars ??
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
The DVD that the Denso conversion program failed to successfully read when I was hoping to create files on the Firewire drive was for a MY16 D4 IIRC. Whilst the Denso program happily formatted the drive, the DVD file format was incompatible which caused the conversion program to abort.
yes, John said in his first post that "The processor within these units is a Renesas UPD35003MNA. This is an embedded device designed for vehicle applications, has triple Arm Cortex cores, and multiple embedded interfaces"
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 826 ![]() ![]() ![]() |
hmm interesting RR 2005 4.4 petrol
