![]() | Home > Technical (L322) > 2.30 amps parasitic draw? 2003 L322 TD6 |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
I was going to suggest alternator as you seem to have eliminated most other possibilities. |
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560
I've had parasitic draws in the past on my 04 and nothing really ever showed up on any tests.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
^@ low
| lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269
nicedayforit, the thick cable that goes from the jump post on the engine side of the of the bulk head only seems to go directly to the starter motor ,am I not seeing something? |
Is there then not another cable looping from the starter to the alternator? |
I just found out there is a hiden fuse box inside the Ebox in the engine compartment which I did not see, so will pull those fuses also.
To test for current a from jump stud to alt, I place the amp meter between the lead and the stud,, I assume i need to reconnect the negative cable back onto the batter first? I don't want to damage my multmeter . |
| NVB Member Since: 14 May 2017 Location: Essex Posts: 103
You really need a clamp meter to check for parasitic drains. Disconnecting cables and putting a multimeter inline will often 'wake' the car up again.
MY BAD,! it's not 2.30 Amps, I misread the new meter. its 0.230 amps.
0.23 amps is still not good...
Update, I found a shorted couple of wires in the spare well, they were for my reverse camera i had installed in the bumper a while ago, the wiring had rubbed through on the body work. The pos wire seems to be live and is shorting to earth. this may be my problem. . |
