![]() | Home > Technical (L322) > Remote unlocking stopped working |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
No thoughts |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8117 ![]() ![]() ![]() |
Sounds like a faulty reciever unit if it’s both keys.
Thanks Alistair, as you say a clue in that thread |
After reading the thread Alistair linked to, I tried holding the keys close to where the amplifier is mounted and hey presto both keys work fine , 6ft away by the drivers door (lhd) neither work.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1425 ![]() ![]() ![]() |
If it's working when you hold the key nearer the receiver then it might just be the batteries in the keys, try changing them & see if things improve. Some of the keys seemed sensitive to lower quality batteries so get the best you can. Only Range Rovers since 1988 |
I think I have convinced myself it is the amp as both keys stopped at exactly the same time, so have ordered one, will advise the forum on results in a couple of weeks when it has arrived and been fitted.
07MY have self charging keys so can't change the batteries like on a later model... I would agree the amp is probably the cause |
Thanks CTC, my thoughts too |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I would suggest you try a battery first. Many systems are programmed when the batteries are low to lock but not unlock. It’s a failsafe type situation, you don’t leave your car unlocked but you do know there’s an issue when you unlock it because it won’t unlock from a distance. Batteries are cheaper than an amplifier anyway, give it a go. BMW i3 Electric Car
