![]() | Home > Technical (L322) > Timed climate control |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
it may be too warm at the moment for it to turn on, it wont bother igniting if the temp is above a certain figure, which I can't remember off the top.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine is doing this too, its the battery in my case. The battery starts the car just fine but is apparently too low a voltage to run the heater. I have proved it by leaving a C-Tek charger on overnight and the heater starts up and runs fine. BMW i3 Electric Car
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Thanks guys,I've tested my battery this evening as the car hasn't moved today so I should get an accurate resting voltage i think? The voltage is 11.8v engine off,which suggests it's fubared,though puzzlingly still starts the engine sharpish.I try charging the battery overnight then see IF the heater fires up correctly,incidentally is there such a thing as a nice easy way to charge the battery in situ by simply connecting a plug into the car towing socket wired from a 12v charger to put juice IN instead of crocodile clips onto the battery or would relays etc wired in prevent that method? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
If its a 13pin socket pin 9 is +ve pin 13 -ve, if you have the two 7 pin sockets, the grey one (12s) pin 4 +ve pin 3 -ve. BMW i3 Electric Car
Great! That's really helpful,thanks! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
have a look in the forum shop.......
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7996 ![]() ![]() ![]() |
Just beat me to it....
Or....
Well I'm stumped over this climate heating! |
